I missed the first group buy on these alarm system...How soon you looking to buy a new account I'm waiting on approval for has them..lmk
depends what you want to shut off....fuel or ignition.what color is the wire or wires that have to be cut to put the igition kill wires onto
This is actually not true. If you carry the remote control, you can approach the bike even with the perimiter sensor engaged. The alarm will not be triggered. As soon as you turn on the ignition the alarm will disable itself. Turning off the ignition will cause the alarm to arm itself after 3 seconds but again...the alarm won't be triggered because you carry the remote.If you use the perimiter sensor, or you like to get on the bike before you start it, you will set off the alarm.
It can be picked up either right off the connector at the ECU or if you pull the tail as I did you can splice it right at the fuel pump relay just to the left of the battery.Thank you and where can this wire be found
