(InsertOriginalNameHere @ Jun. 05 2007,12:23) I assumed that both batteries were essentially hooked up to the + of the main battery and then the secondary was just grounded to the chasis.
Is this incorrect? If so, how is the secondary hooked up.
If this is correct, why wouldn't the alternator charge both at the same time?
IMO, not sure if there's a higher cranking amp battery available for a motorcycle to possibly give a better benefit than the sluggish single stocker. But I'd love to just get rid of the stock battery for a relocation so I can use a readily available battery from Walmart. I never remove the stocker over the winter and I've had to replace it the last two years. I know, my fault.
