piratediverjefff
Probably,may have to pull the wheel a little more forward.If you do much highway cruising you may not like that much gear though,that's about equal to 6 more teeth than the stock 18/43 and will raise your rpms at least 500-600+ at cruising speeds...and get used to wheelies.With my 18/47 and a 55 series rear tire the difference is more like 18/45.5(due to the taller tire knocking about 1.5 teeth off of the true ratio)and is plenty of gear for general street riding(I had to add 4" of wheelbase just to keep the front end down in 1st gear).If you were Arch's size(which is like riding 2 up all the time...no offense Arch)then a bunch of gear would be fine,but at your 175-185 I personally wouldn't go that much(if I ever go back to a 50 series rear tire or lose 50 lbs. off my fat ass I'll drop back down to a 44-45T on the rear).
