shooter7712
ok does anyone have the wiring diagram for a the gear indicator. i am trying to setup a duel stage waste gate (turbo xs). i am not sure how the sensor works, but i would like to set it up to run 8lbs on the first stage and then trigger it for 12lbs in third gear. it is set for 12lbs now. also want to wire it only so only the first stage works until switched (run thru a toggle switch). any help would be very appreciated. mike
