Getting it to work so far, long way from finished
it fits behind the front wheel, but i need an adaptor to move the oil filter ,
Iused my gt35r header jig but with t4 header plate to dummy up the headers and get an idea of where i wanted to run the pipes for split pulse
and was totally surprised when the S362 fitted just about perfect , hangs a little lower than a garrett on same headers and i have a scavenge pump on hand in case its needed
the EFR series look a bit bulkier with there inbuilt wastegate and BOV, but you would have more room available not needing an external gate , esp if your dumping the exhaust straight out the side
My LSR use needs the exhaust out the back so it all gets tighter and i will be compromising exhausrt flow a little stepping from 3.5 inch at the outlet to 3 inch exhaust
i expect this is bigger than the EFR , still to cut the compressor outlet , divided entry wastegate will go under no 4 exhaust in the space
You should talk to someone more familiar with the BW turbos, the smaller 7670 may even get to your target and have a lower boost threshold , this big bastard came about after running the Colorado mile and finding i was using all the power the US bike had by 3rd gear and it was time for a step up
