BIG CC RACING
While it didn't make 600hp yet, it did make 506 @25psi. At that point we were getting 25whp per psi, so at around 30psi you would be well over 600hp.
I would like to see the maths for that. A 150hp low comp turbo engine to break normal atmosphere (of 1 bar) gives approx 180 to 190hp. If going positive it then make 25hp per psi you would be seeing 25hp x 25psi = approx 625 plus (not forgetting) the 1 bar normal atmosphere base level of 190 odd making 815hp at 25psi & at 30psi you would be 940hp.
At 506hp @ 25psi which is good power by the way I would calc that as 506hp-190hp (guessed power at atmosphere) = 316hp divided by 25 = 12.64hp per psi.
For those that don't understand power at atmosphere, if a turbo bike makes 250hp at 6psi & then makes 310hp say at 12psi & 370hp at 18psi you can see it makes 10hp per pound of boost so if you subcontract the initial power gain at 6psi of the same 60hp it would be reading 190hp. That is not the aspirated power of the engine though. It is the power the bike makes to get to normal atmosphere from vacuum before then going positive into boost as the turbo is still feeding in air.
As a rule of thumb on petrol a Busa without intercooling makes from 8-11hp & with intercooling from 11 to 14. Other factors such as compression & engine size & turbo size & boost efficiency etc etc will vary that.
