OB_Cisco San Jose
Like to thank Lyle and 99TLR for the tips.I checked my battery voltage first and also all electrical connections,checked under the gas tank for hose connection and found that the first of two hose that come from the gas tank was almost all the way off at the connection point located near the frame unit.I'm not sure what unit is wrapped under the foam/rubber shield since I do not have a repair manual,I think it might be the electronic fuel pump,anyways after pushing the hose back in the raw gas smell went away.I'm going to have to wait until the bike is cooled down before I make sure the F1 error code problem goes away since the problem happens when the bike is cold.One more quick question for the people that have adjusted their cable slack on the throttle control,is it done from the handle area or near the gas tank end?I did mind at the handle end since I do not have a service book.Thanks again to all.
