homermacleod
For the past two months, my bike has been having problems starting (2006 Busa).
It starts fine in the morning, but when I get to work, if I turn it off and try starting it back up it clicks once, and stops. If I hold the ignition button more then two seconds after it stops, the lights on the instrument cluster go off and the time gets reset back to 12. After it cools down, the bike starts fine again.
This morning, I drove it to work and when I tried to start it 10 minutes after shutting it off, it tried to turn the starter and stopped again. The lights on the instrument panel went out again. This time, the lights would not come on again. I left it alone and came back an hour later and it will not power up when I turn the key to the on position.
I figured that the battery is dead and had a coworker take me home to get my battery tender to charge the battery. When I plugged it in,
the green light stays on steady (battery is fully charged).
Does anyone have any ideas on what the problem could be?
-Chris
-Chris
