Sorry that didn't work out. It's probably, as previously diagnosed, most likely your fuel pump. Try spraying starting fluid into the throttle bodies, if it starts, it's fuel. Your plug threads could have melted due to heat, sometimes it happens when engine is extremely hot & plugs are removed. You could replace them & try the starting fluid, if it doesn't work, possibly someone more experienced can give additional advise. I'm new to Busa's but not to bikes, good luck.
