Stock Steering Stabilizer
BusaReds
I read a link about changing the oil in the stock steering stabilizer to a thicker grade to tighten it up a bit.
Anybody done this or know what grade is the max I could use to get it nice and snug.
I wish I could remember where I read it...........
<!--EDIT|BusaReds
Reason for Edit: None given...|1104974671 -->
Yes real simple
unbolt the unit
there is a scew on the side remove it
pump out all the oil
immerse the unit in 90w gear oil
pump gently till it's full of oil and runs completely smooth (no air)
put the scew back on
mount the unit
Works very well
Thanks "ohzone"
Dont want to add a bulky aftermarket stabilizer but need something cause she feels a little loose when i launch and the front wheel is skipping across the ground and when i pull second its almost like a lil shake down.........So I think I'll try this first..
