Stretching Clearance Issues-HELP!!!
Calhoun
I just bought my busa a couple months ago and decided to stretch it. I already lowered it maybe 2" or 3" but now with the stretch Im rubbing on the bottom side of the rear fairing. If I put he stock links back on will this resolve my problem? every other stretched hayabusa ive seen on pics dont seem to have this problem. I have no idea. Any suggestions anyone??? :beerchug:
tiger tail and/or stiffer rear spring.
Lots of threads on these topics. :beerchug:
a good undertail and maybe going with the second hole on the rear lowering links instead of the first.
You are more than likely going to end up needing a stiffer spring in the rear, Im sure you can raise the rear enough to help you out but then your rear will be sticking up in the air, As for a new undertail, Your probably going to need and want one anyway, But dont count on that fixing the problem, Would suck to get a new undetail and then just rub a hole in it.
I would start with a new spring, ( Daniel at Cloud Nine )
Pashnit ( Sponsor ) has good undertails ( Yana Shiki )
and adjustable Links are always a plus.
