Dafeimao85
Hi All. The 3D print works! Smooth like butter. I can't upload the video here. But it exactly 100% replica to the keihin Stva... I am out of time today but definitely will try to clear the C28 by testing further...
By the way may I confirm that when 3.9V for the stps the butterfly plates must be 90degree to the throttle body. But for the 0.5v or full close. Which position should it be?
I meddle too much with the stva til I lost confidence. The butterfly valve spring forward to the dash board to form a 90 degree close to the throttle body. By using finger push backward close, I only manage to get about 85 deg to the throttle body.
When close the buttfly valve should move forward to the dash or backward to the brake light? Please advise.
Hi Sixpack577,I cannot remember, but I think the rear of the secondary plates raises up toward the back of the bike when they close?
I will check this afternoon when I get home from work, as the airbox is off my Gsx1k, and all they all work basically the same.
And I was too happy and I drop the fuel tank screw and went into the body. Now I need to open the side cowl to take out the screwFinally solve!
So the final problem that persist my c28 was stps. The sensor!
Yes even though it was within specs for full close 0.5v and full open 3.9v
So what happen was I feel so desperate. I end up WD40 on all moving parts on the stva but still c28. In the end I just suddenly realize the stp is also a moving part. I just oil it out of a desperate move. I suspect the difficult movement create the resistance where it suppose to be created by the stva gear when full close!
And I was too happy and I drop the fuel tank screw and went into the body. Now I need to open the side cowl to take out the screw![]()
