afterhours
wow...why would you ask for some help them argue with everyone that tells you need to upgrade the suspension??
if you are for real and want that bike to ride well then listen...
front- springs and revalve...what is stock is crap, especially for what you want to do. lowering the front took away some ground clearance....put it back to stock and raise the rear, you will steepen the steering angle while keeping the bike off the ground....
rear - get a real shock, what is on there is subpar for a bike this size...if that is out of the budget then get a spring and revalve the rear shock......
set the sag to proper specs and have fun.....as it sits the bike is too low...as you add speed the taxes the suspension, and lowers the bike taking away your ground clearance.
