So I pulled the forks off and took them to the local bike shop to have seals and fresh oil put in. I realize now I made some a mistake when I didn't discuss in detail what I wanted as far as oil goes, I assumed they would defer to the manual. Anyway when I got home and looked over my receipt I saw that they had put in 10w oil. I am not a suspension guy but I knew this a stiffer oil than I had seen recommended in the manual but I figured I would be able to compensate by backing down the compression and rebound damping. With the damping adjusters wide open I can't get the forks to move more than about 3/4 of an inch when I lock the front brake bounce down on the front end and it feels like it is dead solid when it hits that point. Now bear in mind I cross the scales at about a deuce and a quarter so when I romp down on ya ya know you been romped down on. So what my question is, would the 10w oil alone cause this or is it more likely that they have put to much oil in them and would to much oil cause the forks to lock up like this?
