Just noticed today that my rear tire is a 55 instead of a 50. Front is a 50. Seems this would adversely affect handling. True?
Yes, my error. Front is 70.Adverse? No. It improves handling.
PS: Your front should be a 120/70.
Remember, the profile is a % of the width, so 55 doesn't mean it's higher, 55% of what? 190, 200, 180? I went with a 200/55, raises the rear a little bit and makes the bike feel like it's a bit lighter when initially counter steering into a turn. You can offset this with a sag adjustment on the rear shock and add 5mm of sag, in either case neither of these changes should feel like a big difference.Just noticed today that my rear tire is a 55 instead of a 50. Front is a 50. Seems this would adversely affect handling. True?
I've already done thatGet a lower seat
190/55Remember, the profile is a % of the width, so 55 doesn't mean it's higher, 55% of what? 190, 200, 180? I went with a 200/55, raises the rear a little bit and makes the bike feel like it's a bit lighter when initially counter steering into a turn. You can offset this with a sag adjustment on the rear shock and add 5mm of sag, in either case neither of these changes should feel like a big difference.
OK, thank youthe 190/55 tire rises the tail 9 millimters compared with the 190/50 - by that agility is improved
(the 55´s outer dia is 18 mm bigger than the 50´s)
helps a lot
my pers . experiance - top !
How bad is it?it adversely affects my reaching the ground!
The Hayabusa has one of the lowest seat heights of any sport bike that I've found... I have a 190/55 and a 1" jack-up kit on my 2005 and I still have lots of knee bend with both feet flat.
And before you assume that I'm a sky-scraping monster like some guys around here, I'm a little guy at just over 6' in height.
It's not terrible, only a problem trying to back it up. On my toes doing that. I can flat foot normally.How bad is it?
It should be ok as long as you can get one foot down comfortably when stopped. I can't flat foot the bike so when i need to back it up, I get off the bike and push it. It was embarrassing at first but after a while i stopped caring. I had thought about lowering the bike but didn't want to lose the handling.
Same. as stated previously, I get off the bike and push it back.It's not terrible, only a problem trying to back it up. On my toes doing that. I can flat foot normally.
No, I actually brought it back to stock height from lowered. Only a problem when I try to push backwards. Mostly just a matter of getting used to it I think.I too run a 55. Best thing i ever did. Totally changed the handling. I know you are struggling with reaching the ground and feeling secure. Have you lowered your machine? This may help you.
i would put it back to lower height. mine is lowered and i love it though im tall as hell.No, I actually brought it back to stock height from lowered. Only a problem when I try to push backwards. Mostly just a matter of getting used to it I think.
