The MagKnight tank cover will fit perfectly. Just heat it up with a hobby heat gun, or good hair dryer, and push any lifting sections in towards the tank, and hold in place for a few seconds till it cools. Takes a bit of patience but eventually you'll get a perfect fit.
dudewizr - Yeah, please let me know about those Busa stickers! That really looks slick on your MagKnight!
DDBusa05 - if your MagKnight is the standard black color - don't throw it away. I'll buy it from ya!
B & B - I just took my tank sticker off my '05. They are definitely the stickers-from-hell! I used a hobby heat gun to heat the sticker up, then pealed it off. A good hair dryer will probably work. Careful not to use too much heat. Expect it to come off real slow. Applying heat and pealing with my fingers didn't last long. Burnt the s### out of my finger tips! Then I ended up using the tip of a soft leather belt to slowly pry it back (again with heat). That eventually worked (read: sloooowly). After the sticker comes off expect to see a square of gluey mess on your tank. Then you'll say to yourself, "Why didn't I just leave the f#####n alone!"
But don't sweat it..., use some helmet shield cleaner/polish and the glue will come right off, with minimal effort. End result will be a perfect tank surface! Well worth the effort (although I'm glad I don't have to do it again!)
