Thanks Guys! Found a better way to release the air from the clutch lin
G
Guest
After several attempts to purge out the air trapped inside the clutch lines i discovered a very fast and effective way to purge out the air. Make sure bikes level ... turn the handle bar towards the right fully, the top Banjo bolt will now be aligned with the rest of the clutch lines, especially the integrated section of the lines. All that is needed now is just to keep pumping the clutch lever and u'll start seeing air bubbles popping up from the fluid reservoir. Do this til no more bubbles appear. Top up and cover up reservoir and walah!
Terence
