The bikes finally finished.. well almost
card16969
So finally after being apart since october the bike is back together and other than dealing witha brake issue she is running and riding so much better. Took her to Schnitz racing and had her tuned and on a 104 degree day she put down 165hp but her pickup became so much smoother. I did a couple mods including paint along the way, heres what i did and i know i forgot a few things.
sprockets -1/+2
fork seals
stator and clutch cover painted
shift shaft seal
wheel bearings
wheels painted
swingarm painted
frame cover
Paint
hid's
switch backs
undertail
undertail led upgrade
master cylinder rebuilt
tire hugger
license plate bracket cutom built
brake pads ebc extreme pro
radiator fan with muzzy blade
speedo healer
gsxr 1k mirros
fork cover powder coated
rear sets powder coated
passenger pegs and mounts powder coated
bmc race filter
ECU TUNE
D&D full exhaust system
battery
air box mod and sealed
pair system removed
double bubble wind screen
smoked front turn signals
chalfer levers
galfer braded brake lines
suspension adjusted
frankestein bolts eliminated
fork stem bolt tightened
rebuilt/cleaned brake calipers
cleaned clutch slave cylinder
zzz chain
motul rbf600 brake fluid
trex no cut frame sliders
swing arm bearings
sync'd throttle bodies
blue led's
engine ice coolant
smoothed inner pannels
