OB_Badagindo
I absolutely cannot believe that the very same $^%&*^$ fuel line thing just happened to me!!! Thank goodness I had my fairings off and only 1/2 gallon of gas in the tank!
I had a slight rattle coming from somewhere under the tank (nothing major). So I pulled the fairings and checked to see if everything was tight. It was, so I thought I would take it up and down the street in 1st/2nd gear without the fairings to heat it up and see if the rattle started. I pulled into my garage, and listened to the rattle coming a bit from under the tank area. I shut off the bike and raised the tank a bit. I was watching the BACK line on the tank. All of a sudden the line disconnected and it started Whizzing gas down thru the frame. For a second I thought it might be all over BOOM, but nothing caught fire and I just let it drain out.
I cleaned everything up with a mixture of dishwashing liquid spray-down and rinse with water. It's drying nicely with a couple of fans now. Nothing seems damaged. I'll let the harnesses dry our really well.
There you go! Be careful boys, it'll scare the heck out of you.
Any ideas on what the rattle might be?
