normally?...i'd never under-estimate the power of educating ones self...but reading is reading and you can buy all the books barnes and noble are willing to order up for you and it isn't gonna make you any faster or safer until you...."Gain The Practical Experience"....through..."Practice, Practice, Practice".
and here's some tips that will help get you there quicker..
1st?...ya gotta rid yerself of "The Head Demons"...you know...all those little voices of fear that keep telling you are going to fall over....while all the while your tires are sport'in chicken strips that would make colonel sanders jealous...instead?..use those chicken strips as a barometer to measure your continued success..as you...
2. Find a remote, safe paved area in which to practice...then set yourself up a slalom course...(hint: those 16 oz RED plastic cups with a little dirt in'em are cheap and work great)...and then?....
3. Learn how to become "SMOOTH" with all your inputs...as follows..
a. "Stay a gear tall"...this will keep your revs down and greatly reduce the "ON/OFF" throttle characteristics and help you to keep your throttle control "Smooth".
b. "Commit to a gear"...
BEFORE...you make your corner entrance...and as stated in "a." above?...stay a gear tall...for instance?....i like to engine brake on the approach and continuously downshift until i hit the desired speed and revs...trying to keep "The Entrance Revs" between 3,000-5,000rpms...by ear...and at this point if you think your still entering a curve a tad too hot?...thats what the front brake is for...sorta like a "FailSafe Back-Up System" for errors in judging entrance speed..but you commit to that gear so that as soon as you toss the bike over?..you remain "On The Throttle and Under Smooth Steady Power"...so as not to upset the chassis with any harsh inputs of any kind...braking or throttle...and the beauty of the busa is the fact that because it has so much torque?...it's very forgiving and will still power you out of even a 2,500rpm rev and carry you clean through...very forgiving..but maintaining 4K rpms at entrance seems like it's sweet spot in most cases.
3rdly?..."Don't Over-Steer"...if you find that you're having to put a lot of effort into counter-steering?...chances are you're not leaning enough with your hips and shoulders...(most likely the works of the head lean demons you haven't fully exorcised yet
) and you're using the steering to force the bike over...don't do that....the busa is very neutral steering..and with proper rider weight placement (press down with the foot, swing the hips out and dip the shoulder into the turn) the busa just about steers itself through a lean..as you let the tire profiles "Find Their Own Home" with very little if any steering input so to speak and just give the busa it's head...cause if you're fighting it?...the only thing you're fighting with is yourself.
4th?...There's an advanced technic known as "Trail-Braking"...and it does help settle the bikes chassis by applying very slight pressure to the front and rear brakes...just prior to throwing the bike over into the corner entrance...what this achieves is a very slight compression of the suspension which makes the bikes chassis a tad more settled and stable for more aggressive riders who enter deep before violently tossing the bike over...neither is for the faint of heart and are advanced rider technics..first get smooth then experiment with deeper entrances and trail braking.
also...pending your own personal experience?...don't do a lot of hanging off and weight shifting at first...as the first thing you wanna achieve is smooth control via tranny management, brake, throttle and steering inputs...and you'll be amazed at just how much of those chicken strips can be gone riding with your azz planted...cause there's only one way to eat an elephant...one bite at a time..and...
L8R, Bill.
