Ticking Noise
HomicidalOctopus
I took my body panels off to do some mods but I hear a ticking sound I don't know if I ever noticed prior. I took a video of it, Its somewhat faint but in person its fairly noticeable now. Is this "Normal" or a cause for concern. I don't wanna tear into it and have this be a problem down the line.
I don’t hear anything except maybe a slight vibration like a fairing is lose but you said you removed them to mod.
could b injectors or cam chain. when i swapped a full system on my gen 2 and i fired it up without the fairings i could hear a slight tick too.
I have to listen pretty hard to make myself think I hear a ticking noise. Could be an exhaust leak if there actually is some noise that's not coming across in video as well as it does in life. Check manifold for blasts of exhaust hitting your hands.
Sounds normal to me....
I didn't hear anything out of the ordinary...it's a loud beastie....
+1
I have a similar (as described) ticking which I believe is exhaust-related.
Do the exhaust check like Mythos recommends, but my exhaust blasts (at the slip-on) are silent.
I've also noticed the actual ticking softens once the pipes are heated up - leads me to believe it may be the header bolts (swapped the header out in '19 - might have to check those bolts)
It seems pronounced at 20-23 seconds as you zoom over the muffler.
Play doctor (but not like when you were a kid with the girl next door.) Take a tube/hose, put it up to your ear and zone in where the sound is loudest. It sounds like the source is the exhaust output? Or is it echoing from a header leak? This should help answer that.
I agree, probably a slightly loose header bolt that is allowing more sound to escape the combustion chamber. Happened to me before.
