Nope I just spray it all and it goes wherever it goes. If the lube gets somewhere it just aids in cleaning that spot
The 'ol Spray and Pray method
i use a piece of cardboard and bend it into an "L" shape to avoid overspray.
any of u experts got some ideas when chain lubing to avoid getting the lube sprayed all over the wheel and sidewall of the tire? I normally hold a rag under the chain while spraying the lube, but still manage most of the time to get it all over my rim. Yes i spray it on pretty heavy sometimes, but using the dupont i like to spray it thick to kind of wash the chain off while lubing
Long as you don't run the engine to spin the wheel. Graphic pics from the gixers...
How NOT to clean your chain. **GRAPHIC PICS*** : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Guess I'm the only one, simply spray desired chain lube on small piece of rag and wipe onto chain, easy smeasy.
Not sure if you're getting lube in the o-rings that way?
More like cleaning the outside of the chain?
No actually the cleaning is done with kerosene prior to oiling, I believe the residual kerosene within the links allows the lubricant to work into the links & o-rings. Chain is cleaned and freshly lubed after each ride therefore o-rings never actually become unlubricated.
