Here's what's in mine.
I use most of the tools on a daily basis or very near daily, wreching equipment and building equipment on the farm.....then of course building or modifying toys at night.
Arc welder
MIG welder
6.5 hp aircompressor with huge tanks
small compressor
floor mount drill press
steel chop saw
gas handheld chop saw
4 hand drills
2 mini grinders
1 7" grinder
1 bench grinder
2 sawzall's
skill saw
table saw
band saw
2 bench mount spindle sanders
jointer/planer
scroll saw
3 staple guns
2 routers
router table
4 medium roller cabs of hand tools...wrenches, screwdrivers, tapes, squares, files, levels, drill bits, punches, hammers, prybars, and such
2 adjustable honing stones
valve spring clamp
ring compressors
sandblaster
suspension spring compressors
electrical wire, tape, and connectors
tons of air tools
one man bleeder
dwell meter
ohm meter
voltage meter
3 curcuit testers
3 floor jacks
1 jackall
4 bottle jacks
c clamps and slide clamps
2 engine stands
engine crane
2 rivet guns
assortment of hand bodywork tools
2 slide hammers
1 hvlp gun
1 normal
masking paper and tape
water seperator
Beer fridge
40' bench space
1 5x7 steel welding table for jigs and such
6 different sizes of oil filter wrenches
8 jack stands
vaccuum cleaner
pressure washer
2 random orbit polishers
1 high speed polisher
permanent make shift paint booth......works awesome.
and probably a hundred things I'm forgetting
Future purchases
Hoist
TIG welder
wood Lathe
multi purpose milling machine
planer......not jointer/planer
permanent proper spray booth
Newer beer fridge.
another beer fridge, fer when RSD visits.
Nice, But where's your Vise? :tounge:
I have some of them thangs'
but mainly just stuff..
Vacuum guages
dwell
2- digital meters(ohm/v- ac/dc)
2- dc testlights
1- timing light
1- trickle charger
1- full size charger
3- drop lights
1- clamp on light
3- bench swivel lights, 1 w/magnifying lens
1- parts washer
1- 5 hp large tank compressor, and numerous air tools
1- electrical terms kit
3- sets of shelving for bike parts
2- peg boards running on different walls for various tools/parts
1- 10' work bench
over head cabinets runing down one wall of garage for storage, chems, etc.
1- corded die grinder 4" or 6" can't remember
3- bench grinders, all with different wheels for diff. tasks.
3- 1/2" chucked drills corded
2- 3/8" chucked drills corded
1- 1/2" chcucked 18v cordless DeWalt
1- sawzall corded
1- 18V Cordless Sawzall
1- stand alone fuel cell w/ petcock, for working on bikes with tanks off
3- sets of fuel/vacuum line pinchers (they set to close vac/fuel movement)
complete set of C-Clamps ( all sizes made)
1- 10" Vise that rotates 360* lateral & vertical
Complete sets of ball peen hammers
partial Brass punch sets
complete steel punch sets
metal marking pen, also etches glass
metal marking stamps ( a-z, 0-9, caps and lower case)
Complete airbrush setup ( one day i will have time to use it
1- Compression tester
2- different size sets of Honing tools
2- different sizes of Ring Compression tools
4- sets, diff sizes of harmonic, wheels pullers
1- set steel feeler guages
1- set non metallic (brass) feeler guages
1- manual valve angle grinder
1- mechanical valve angle grinder
1- Complete roll around tool chest, tooooooo many tools to list here, it would take up too much room..
I am sure I am missing alot of my tools referring to bike use only.. :tounge:
Don't forget the measuring cups for oil, and other fluids..
more funnel various sizes than I can remember.
2- Oil catch tanks, 1- 15 qt (oil), 1- 6qt (transfluid)
1- open catch tank for antifreeze
scrolling jig saws, non scrolling jig saws
1- corded flat sheet sander
complete set of brushes from large to small, steel & brass
1- lrg bag of steel wool, various compounds for polishing, waxing, etc.
stock of angle iron, and aluminum
2- sets of organizing bins for misc bolts, etc.
1- rack for helmets
1- set of Ez-Outs
2- complete sets of Tap N Dies, metric, & Standard
dude I would go on, but my fingers hurt...
Oh did I mention the stand for the Busa?
or the restored 73' Super Beetle in my Dang WAY!
ramps, lifts, stands, etc. got em just gotta find em in this packed large 2 car garage
anyways, that's some of the stuff, have alot more, but I can go any direction you want to here about
j/k but not..hehe
Peace,
Busafied
