G
Guest
Rob - I wanted to let you know how my problem turned out. My bike started dying again today - about 20 or 30 minutes into the ride. Just did not want to run at all - very strange after running so nicely for the first 1/2 hour. I got home (finally) and pulled the codes on it [while it was still doing it this time] using the dealer plug. Guess what popped up?! C23! I pulled out the trusty Service Manual and after a little research found out that C23 is for the TO sensor. TO = TIP OVER sensor! I located the connector to the sensor and it looked like it had been rubbing on something - it was discolored a bit - was rubbing against something black. There are voltage and resistance checks listed to perform but the manual's first suggestion is to check the connection for shorts/bad connection. I sprayed a little contact spray and plugged it back in. BINGO! I went and rode the wheels off of it for nearly 2 hours - problem is gone!! Apparently there was a short or bad connection in the connector feeding the tip over sensor box and it was ACTIVATING! I can say for sure that when activated this device DOES work! I'm very happy now and ready to head to the Ozarks for some fun. Just wanted to let you know just in case you or anyone else has a problem like mine and it's not being caused by plugged fuel filters. I have not heard of anyone else ever having this problem with the TO sensor plug.
[This message has been edited by Todd (edited 14 May 2000).]
