Transmission repair
PocketRocket
Hey Guys on a 750 GSX is it a big expensive Job to fix the trans? Does the motor have to come out?? Thanks for any advise!!
PR
yep, you will have to remove the engine.
As for it being easy to repair; that all depends upon your abilities.
I can rebuild an auto trans all day long but have never worked on Bikes...Does the 750 have a radaitor , oil cooler etc and will the head ( top of the engine need to come apart? Thanks PR
(PocketRocket @ Jul. 18 2007,00:31) I can rebuild an auto trans all day long but have never worked on Bikes...Does the 750 have a radaitor , oil cooler  etc and will the head ( top of the engine need to come apart?   Thanks  PR
Yes, radiator, oil cooler, etc.
Fairly sure you'll be removing the head and splitting the cases. Most sportbike engines will have to be taken apart to get to the tranny - I know the Busa engine does...
