The location of the indicator is up to you. The Gear Position Sensor (GPS) connection is located under the fuel tank, close to the seat on the left side of the bike. If you would like the indicator on the right side of the bike, a wire extension is needed. Keep in mind direct sunlight on the digital indicator will make it harder to read. For this reason, it is suggested that installation should be as close to the gauges as possible. In some case, you may need to lower your head to see the indicator directly. You may be able to see and read it though the windshield.
Remove the plastic upper panel covers by unscrewing the center and side Allen head bolts and upper body pin. Remove the body pin by pushing the center in which will collapse the lock, then pull the pin out.
You may need to hold the circular part of the fastener in place to pop out the pin. After the pin and other fasteners are removed, pull the upper panel from the pin location toward the fuel tank and the panel should come out easily.
Once you have determined your installation location drill a hole, just a bit smaller than the digital indicator, 5/16" should be fine. Using a razor blade or Exacto knife, carefully trim away some plastic to create a rectangular hole just a hair smaller than the indicator to allow for a tight installation.
The plastic will give a bit. Just remember, less is better. Take your time. Use some silicone on the under side of the panel to give a weather tight seal.
With the indicator in place, connect the wiring. This device uses 4 wires.
Red
+12
Black
Ground
White
Pink wire to the ECU
Green
Pink wire to the GPS
The diagram below is the normal wiring for the Gear Position Sensor. The blue wire links a ground signal to the neutral light.
The diagram below is the wiring for the I² . The pink wire is removed from the connector from both the male and female side and is connected to the green and white wire accordantly (white is represented by yellow on the diagram) from the unit.
The green wire from the I² is connected to the pink wire going to the GPS. The white wire from the unit is connected to the pink wire going to the ECU.
THIS IS BY FAR THE HARDEST STEP.
Removal of the Pink wire from the connector housing.
Unplug the connector to the GPS. Using the enclosed T-Pin, push the plastic pin lock off the connector tab by inserting the T-pin between them. Once the tab is unlocked, the connector will slip out of the housing when the wire is pulled. Repeat this again with the other connector.
Use the installed connectors on the I² to connect to corresponding connectors. See picture below. Using enclosed heat shrink, weather seal the connector. Use a blow dryer to shrink the tubing. DO NOT USE FIRE. These connections are under the fuel tank.
Connection of power and ground lines.
A keyed power line is located behind the instrument panel on USA models. To remove the instrument panel, remove the right upper panel as described above. Remove the 2 10mm bolts on the bottom of the instrument panel.
Pull the instrument panel towards the fuel tank to separate from the upper holding prongs. Disconnect the wiring to the instrument panel by pressing on the detent and pulling on the connector. Remove the instrument panel.
Locate the European light connector. The connector has two wires, black/white and brown.
Connect black ground line from the I² to the black/white by pushing the male tab into the female connector. Connect the red power line to the brown in the same fashion. Use enclosed ties, tie the wiring in place as pictured below.
Reinstall instrument panel in reverse order carefully.
Once all connections are complete and confirmed for proper connection, reconnect battery, turn the motorcycle on and check for operation. If the bike is in neutral, a lower case N should appear on the indicator. Changing gears on the motorcycle should have an immediate reaction on the indicator. Note: If the indicator maintains a "E", check that switch 3 is in the on or closed position.
Switches 1 and 2 are setup as a binary bit recognition system. The sequences are determined by the positions of the two switches. The table below shows corresponding switch to sequence combinations.
Switch 1
Switch 2
Sequence
On
On
5,N,5,3,4,5,5
Off
On
4,N,4,3,4,5,5
On
Off
5,N,5,5,5,5,5
Off
Off
6,N,6,3,4,5,6
Note: Switches may show open instead of off. Open = off and closed = on
Confirmation - The indicator will flash the sequence number for ½ second before relaying proper gear information every time the unit is powered on to confirm the gear sequence to the operator. If the switch positions are changed during operation, the new sequence will not be use until the next reset (power down, power up).
TRE Bypassing
The on board TRE is by-passable by moving switch 3 to the off position. The white wire from the unit will not be needed. The green wire will be tapped rather than spliced. See illustration.
Now go ride the best bike ever made!
Home
9026 Gill Bridge; San Antonio, 78254
