So I have a 2012 busa with a rcc stage one turbo and a full exhaust. My wife made a pass down the track and it came back smoking a lot. I found that the turbo had some shaft play so I sent it out for rebuild. I also redid the return line (first setup had a 90 degree elbow at the flange and a hose going to the oil pan, now it's a straight fitting from the flange with a braided line), and made sure the crankcase breather wasn't obstructed. Put it all back together and once warm blue smoke pours out at idle. Do I need a scavenge pump? My other rcc stage one kit is identical and ive never had an issue. Oil level is right where it should be. Any help is greatly appreciated!
