heres what I can find
IgniTech
The unit is programmable through PC. Adjustment software
IGNIJET MAX POWER.EXE for PC is a part of supply; you may choose required settings of advance, fuel map and peripheral functions. Older version of the unit used
IGNIJET04.EXE and
IGNIJET02.EXEsettings software.
The unit is currently produced for some particular motorbikes used in road motorbike competitions (DUCATI 996, GSX-R600, GSX-R750, GSX-R1000, GSX-R1300, TL1000, ZX12R, ZX6RR, CBR600F, CBR900RR, CBR600RR, VTR1000, APRILIA RSV MILLE, R6, R1). Different sensor system can be implemented in the unit software on request.
Ignition unit includes the feature of adjustable curve of advance as a function of rpm. There are 10 revolution - advance couples of adjustable values. Interpolation of the ignition between these values is linear.
Fuel part of the unit includes adjustable 100-point fuel maps separate for inner and outer cylinders and other adjustment features.
Racing utilities: Two-level adjustable limiter. Adjustable gear shift control signals reaching and exceeding optimum gear revolution. Adjustable clutch master switches off the ignition during gear shifting. The unit further contains N2O dosage controller. Adjustable servo controller can be used for exhaust throttle or induction tube length control depending on the engine revolution.
The unit is made as TYCO connector version (the same as older IGNIJET 02). Assembly to a particular bike means either replacement of connectors or adequate reducing bundle. For selected motorbike types (so far GSX-R, TL1000, ZX12R, ZX6RR, CBR600RR, R1, R6) the unit is produced with an original connector.
There are two versions of the unit - full version and limited one. The limited version does not include racing utilities and revolution limiter cannot be adjusted higher than the value of motorbike series.
The unit does not include immobiliser.
you neeed all of your sensors
it uses
*Crankshaft position sensor CMPS.
*Throttle position sensor TPS.
*Induction air pressure sensor IAPS
*Exhaust servo position sensor STPS (Gen 1 hayabusa doesnt have one not sure about gen 2)
*Air temperature sensor ATS
*FALL SENSOR tip over sensor
*Induction coils IC 1, IC 2, IC 3, IC 4.
*Main injectors INJ 1, INJ 2, INJ 3, INJ 4.
*Secondary injectors INJ1B, INJ2B, INJ3B, INJ4B
*Intake servo position sensor STPS2.
*GEAR POSITION SENSOR
