It’s funny, coz last night I just went thru the whole procedure of timing cams and mine also has a APE manual tensioner!Hell yes. Thank you, now I do understand how that tension works and it make perfect sense. I figured it had something to do with the pressure from the lobes hitting the buckets! Brilliant Kiwi!!
It did stop turning and I figured that timing is now off, hopefully I didn't crank on it too hard cause for about fifteen minutes I couldn't figure out why it stopped. I don't think I put more then 20 nM on the crank?Atm I'm removing the cams. Then I'm going to figure out how to see if I damaged the valves. Thank you again for your guidance!!
The secret to successfully timing the cams is to cable tie the chain to the cam sprockets BEFORE torquing down the cam journals... in doing this it’s impossible for the chain to jump teeth on the sprockets.
Once you have it timed, journals torqued, then wind in the tensioner and you can see the slack in the chain BETWEEN the sprockets disappear and go taught.
I’m so glad you understood what I was saying, that made my day!
