madlyhs
Last night my brother and I started the bike for the first time (as Turbo Busa) system is running fine we noticed a small oil leak will fix it soon.
The installation manual did not specify where to connect the Boost gauge! So for my testing purposes I connected the gauge to the last Throttle body 4 (next to the new fuel pump). I removed the terminating plug on that throttle and inserted the Boost gauge hose to it my question is this the right place?? Need to know that I am reading the right boost level please help.
We also noticed after starting the bike the RPM was reading more than 2.5 RPM! Before the Turbo the RPM would read 1.1RPM so is this normal or do I have a problem?? I am still waiting for the power commander to finalize the installation could this be it??
Is it a good idea to install an Oil pressure gauge, which one do you recommend?
Thank you in advance
<!--EDIT|madlyhs
Reason for Edit: None given...|1088396065 -->
<!--EDIT|madlyhs
