jellyrug
Fred's answer: "The water in the bottle, taken all as a unit/system, has not released all of its latent heat of fusion (see Enthalpy of fusion - Wikipedia, the free encyclopedia) and needs to release just a tiny amount so that all of it becomes a solid. As you can see in the video the water in the bottle remains as a mixture of water in liquid and solid/crystal form. That's because most of the latent heat of fusion had been lost, but not all. The vibration on the bottle caused most water molecules (which were ready to enter into the solid phase), to release the tiny amount of heat that wold allow them to join other water molecules into crystals. Therefore, most of the water turned to ice and the small amount of water remaining took the heat released from the crystal forming molecules and stayed liquid, still at 0 Celsius. If the bottle had been left alone long enough it would have solidified eventually when all of the liquid water had released its latent heat of fusion. The fact that the water is filtered helps delay the onset of crystallization by removing potential nucleation centers."
I don't agree with Fred, by moving the bottle, or shaking it, however minute, he is actually adding latent heat (Energy) to the bottle and it's contents.
Cwagmire hit it right on the nose, I agree with his theory.
"It is called supercooled water. If the water is extremely pure, as in has very little to no particulate in the water, there will not be any nucleation sites in the liquid, which is required to start the freezing process. Once the bottle is shaken or disturbed, air bubbles introduced to the liquid will act as nucleation sites around which the water will begin freezing. Once it begins freezing, the ice will spread until the entire bottle is frozen."
