I stripped the oil drain plug on my 2002... I just replaced the pan... I didn't wanna run the risk of any metal shavings anywhere.... it was a PITA... AS USUAL... exhaust had to come off.... a million bolts... smh… I think im just impatient though, my down time is getting more and more valuable to me as I get older.... I USED TO enjoy wrenching on my bike..... nowadays I would rather have a tooth extracted without novicane than work on the bike, coupled with the fact that it looks like a spaceship to me.
If you have a Gen 2, and pull the pan, there is a seal washer on one of the pan bolts. Make sure you put it back on and in the same hole or it will leak.
I used a 1/2" oversized self tapping drain plug.
Like stated before, I started it and then backed it out to clean off the chips and then repeated.
When all the way through I then used a vacuum to suck any tiny chip that might have gotten
just inside the pan. Then I sealed it with the red stuff. I reseal it at every oil change too.
So far never had a problem and that was over 13 years ago.
Mine stripped before it ever made contact with the pan and yes it was put in straight.
I have no idea between my Gixxer and Busa how many oil changes have been done. But I ALWAYS use a torque wrench. And always recomend using a torque wrench when you're going onto aluminum. It is just to easy to hurt the threads.
Been having some very minor problems with slight oil leaks from my drain plug after the last two oil changes. Prior 6 changes...no problem. Dealer says my threads are a little screwed up (probably my fault as I wrenched the drain plug down tight to prevent any leakage). He put some teflon tape...
