CorrodedAlien
good reading off the link.
I already gave one reason they will wear/cup on one side before another, so that one doesn't require repeating.(Gunnybusa @ Sep. 19 2006,18:34)And those reasons would be?(Quasar @ Sep. 19 2006,15)Unfortunately, your statement is 100% incorrect. All front tires do NOT cup. Some do and some don't.(mikeo @ Sep. 19 2006,16:35) All front tires will cup. All the reasons covered can accelerate the cupping.
I've had PLENTY of front tires in my 31 years of riding that didn't cup all the way down to below their wear markers. My front Pirelli Diablo Corsas and my Sportec M1's did NOT cup on my Hayabusa, tire after tire. There are a number of reasons why some tires cup and others do not.
They wear on the left side because of the crown of the roads. Roads aren't flat, they are crowned so there is water run off.. therefore the left side of the tire gets worn down first.(Lamb busa @ Sep. 20 2006,03:31) Always wondered that anyway!!!!!>>>>>>>>>>>>>>>>>>>>>>>>>>>>All my tires always wear more on the left sides.
Lamb has never had a cupping problem on 'missile'. Although the twisties just burn the edges off the tires b4 lamb gets anywher near the cupping stage near the center of the tire!!
Ditto! I never leave the garage until I check/adjust tire pressure! MC tires typically will loose 1 or more PSI per week.(05 Busa LE @ Sep. 19 2006,06:17) Man ... I check my tire pressure before each ride. Seems like a pain, but worth it. Maybe I'm a little OCD, too
Holy cow..i just bought a vintage 1997 busa..very rare
Posted via Mobile Device
You need to have your suspension adjusted...it is similar to having worn shocks(CAT3 @ Sep. 18 2006,22:48) Looking over my Busa this morning, I noticed the left/outside tread of the front tire is cupping. *WTF?
on the front of your car...in a turn if your front end isn't set properly, the tire is rebounding
off the pavement causing the cupping *
Mine was due to the tire being mounted backwards. Hope that helps!
