if you want to add something that "might" help cooling. a "wetter" should help. it is a surfactant that helps break surface tension of the water and can allow a better heat transfer between the coolant and the metal head/radiator..
Again.. Engine Ice is simply Propylene Glycol (they have to state this per Fed Regs on the MSDS) Save your $$ buy some Redline water wetter and add it per instructions to either ethylene glycol or Propylene glycol based coolant..
Not sure how "engine ice" got all this "street rep" in the bike community... but it really is nothing special... but it sure got some fancy marketing... (GM was one of the first to use Propylene glycol in the Vette as it ran at a steady temp of 220+ and Propylene glycol could not take the beating)
