OB_Bill Koz
Valklex - What viscosity do you need? 5 or 10 on the index is not going to make a difference. Just use the higher viscosity in the summer or hot weather. The flow rate for synthetic base oil is much greater then petroleum based oil. Temperature has little effect on synthetic flow rate. The wider the viscosity range the more additives. The one thing to remember about additives is that they can cause problems. When some additives are burned and mixed with hydrocarbons and carbon monoxide (become high corrosive acids) and circulated throughout your engine. I believe the least amount of additives the better.
Koz
Koz
