What next?
Klutch556
Ok you glorious bastids!
While I got her all tore down and on the lift... what else should I do?
small mods, quality of life, performance?
Nothin huge either, I know y’all... no turbo (yet) no CF wheels (also yet).
wuzza got me thinkin last night when he brought up upgrading the cushdrive while I changed the sprocket. $50 for a solid upgrade. What else?!
So far:
ECU flash
Braided clutch and brake lines
4 over swing arm
front/rear supersprox sprockets in rear
lowered front/rear
Upgraded to 16.1kg rear spring
Under tail delete
Akro 4-1
Saddleman seat
Rectifier relocated
Few other little things like spools and puig oil cap that you need a wrench to remove to prevent tampering.
Pazzo or "novelty" levers.
Mirrors with longer arms or raise plates so you get a full view and not a view of your shoulders.
Cool gas cap.
Rearsets.
Side mount tag/plate.
Bar ends,novelty or colored.
Top clamp/upper triple tree aftermarket on fancy protective sticker.
Gas cap cover.
Chain guard for your longer arm.
Tinted lens brake and/or tail.
Different windscreen. color and/or dubble bubble or touring.
Frame plugs.
Aftermarket clutch and stator covers. Woodcraft ally,clear,kanji,annodised.
Colored or other accent bolts. Plastics,etc.
Custom grab rail.
Brake rotors.
K & N oil/air filters.
Tank protector.
HID's.
Hump mod/s.
Raised decal for swingarm. "Busa" "Hayabusa" "GSX1340R" etc.
Decal removal.
Rim tape. Colored stripes or "Busa" "Hayabusa" "GSX1340R" etc.
Rear air suspension to lower rear. or links or raise.
Lower pegs for touring.
Raise top clamp for touring. Cheap way(spacers).
Heli bars.
R1 wheels. GSXR 1K wheels.
R1 or Brembo master.
Custom seat/s
Powder coated everything.Peg hangers etc.
Carbon fiber stuff. Front fender etc.
Gauge face plates.Colored or white or colored lights or 200MPH.
1 or 2 classy decals. (I sport 1 decal on my tail above tail lite) "200 MPH Club"
Cruise control.
Colored drive chain.
Custom 90 degree valve stem add ons for easy air check/fill. Plus custom caps. Dice, 8 balls,etc, LOL.
Seat cover. Gel,grafx,etc.
Under body lighting. LOL.
Grips.
Plug and mounts for yer phone,GPS,GoPro etc.
Upgraded battery. Lighter and/or more CCA.
Weight saving ideas like battery etc.
Colored or titanium bolts thru out.
Headlite cover.
Custom brake and clutch res caps.
You can polish or chrome lots of things if shiney is your thing. It's endless there.
No remove rear seat helmet locks.
Cool looking kickstand w/without adjustability.
Frame,swingarm,front axle sliders.
Cool swingarm spools.
Fairing screens.
Yoke caps.
Fork caps.
Custom fast remove seat bolts.
Gauge cluster bezel.
Carbon or painter inners.
Custom frankie bolts.
Or just go....
1621874
YA LAZY BASTID.
1621876
1621877
:banghead:
Oyaaaa...The #1 cheap add on fun factor....
1621875
RUBB.
