I think it's important to understand why there is a need for a damper. I assume that we all know that the forks being at an angle move the contact patch back which creates the self correcting force for the front wheel.
Aside from landing a wheelie with the front crooket, or hitting a pothole there is one daring scenario for any powerful bike which can come into play every time you get on the gas hard, even going straight but especially exiting a turn when the bike is not straight.
We may not realize, but 1) when we accelerate even straight we may hold the handlebars a little tight thus creating a small steering input. 2) When we are in turn, believe it or not, we have to have a steady steering input in the bars, otherwise the bike will start straightening out - one may argue about more or less of steering input depending on tire profiles, rider's hanging position, etc. But it is there.
Both cases do not normally cause a problem because the self correcting force of the front wheel is more than enough to compensate for it. HOWEVER, when accelerating hard and getting that front really light the self correcting force may become very small, for just a moment, and the rider's unconcious steering input forces the front wheel to turn a little too far (a few degrees - that's all it takes). When the next moment the front gets heavy again and the self correcting force reappears, the front wheel is too crooket (albeit by a few degrees) and gets thrown by this force (which is very strong because the front wheel is too crooket). There goes the first swing of the tankslapper.
From this moment on, it's the damping ability of the damper which may cause the slapper to subside, or to let the swings get wider and wider...
What conditions will contribute to the possibility of a tankslapper? Tense on the handlebars, rough and/or wet pavement during hard acceleration. Ideally, the damper should offer resistance for very quick movements of the handlebars, and little for the normal movement generated by the steering input. So, it's not a trivial mechanical device.
However, I personally don't mind simply putting a heavy oil in the stock damper and having a bit heavier steering input but providing a strong damping for a tankslapper-like oscillations.
The whole scenario is like a take off. You would rather have the front in the air, but not in that unstable state of barely skimming the ground.
I also realize the factors that a rider controls: the more your upper body hangs off the bike (and I don't mean sticking the knee out to only see the head on top of the tank - the head should be facing the mirror) - the less steering input is required to maintain the bike in the turn; the more relaxed the grip is (there was a good example comparing it to the way you would hold a bird in your hand) the less the steering will be affected when the front gets light.
It is a rare event and may not happen for years - well depends on how hard the riding is done, or when you are going to encounter that combination of conditions. But that's what it is.
