What type of gains will i see??
bigbadboy
currently making 181 to the wheel with brocks exhaust, pc3 brock map and filter. what types of gains you guys think i could see if i got a custom tune for it and got the pc ignition module? i know being able to add timing here and there will help with more power but is it worth it or is it money better spent else where
I am sure you will not see much more gain in a custom map if the map in your PC was done by Brocks just my 2 cents
We got 184.7 HP from an M4 full exhaust and a Teka box tune. You won't know if you'll gain anything from a full tune unless you give it a try?
Did you get a baseline pull before your mods? That means much more than what the dyno says after mods. We gained 7 HP from the M4 exhaust and teka tune.
It all depends on the tuner, and how much time is spent building the map... The ignition module can unlock a ton of power on some bikes (the new CBR's for instance). Again, it all depends on what set up you are running and what kind of power you want to make... I say go for it!
yea made 170. the day i bought it the before i took it home i had all the mods put on. i just recently redyno'd it because i never got it dyno'd after the mods till now.
So thats 11hp more over stock .......how is it TI-FORCE is "claiming" 22-24hp over stock? I know dyno hp is not real world, BUT COME ON, how is brocks supposed to be a better dragrace exhaust system? DAMN im having a hard time choosing
:cursin
