Check fuel filter, the fuel injectors, running seafoam could help those tremendously (did I spell that right?) then check compression and your head gasket. I'd take mine to a dyno as well and get it tuned but these are things you can do in your garage for just a couple of bucks. You can also check your throttle bodies to ensure there is no debris or trash built up causing them to give less air..... JS
