RedBusarider
I had my tires on for TEN years !
So there.
I actually changed them because I was afraid of them not having enough grip - the tread was fine and I'm sure I could have gone a long time
before wearing out the treads. Tire technology has to have improved in 10 years, so that was the other reason to change them.
I believe you have the bead broke.
When I changed mine I thought I had the bead broke and yet I found it really hard if not impossible to get my
No-mar bar in between the tire and rim. What I discovered was that the bead was NOT broken. I went back and used
a lot of force (remember 10 years old) and there was a loud POP when it did break the bead then it was easy to get the bar in and
the tire came off without a problem.
Remember when you get ready to put the new tire on - set it in the sun (if possible). I think I set mine in the sun for ½ hour each side.
Lubed it up and had no problem pushing the first half on and the rest wasn't to bad either.
Are you doing both front and rear?
My sprocket came off real easy and the cushions were in good shape. With the sprocket off you should have more room to push the bars down.
Are you going to be able to balance these when you get the new tires on?
So there.
I would have the sprocket coupling sticking up which does not allow the levers to be pushed down as far---if that should be necessary. I have removed from the sprocket side on other rims.
