why only low beam HID?
I just ordered the 35 watt high and low in 5000K from DDM.
I plan on using both during daylight driving,.... I want to be seen.
I will let you know how they work.
I found the low is more then enough to be seen in the day time. If you blind the other drivers with a light that can make the sun jelous it just may casue the divers to hit you anyway.
also I did the 6K lights. I found just that subtle change to blue helps draw peoples eyes.
I hear what you are saying.
The hint of blue is enough to get me busted.
I figure I can talk my way out if it looks like the same color as OEM.
I only ride in bright sunshine (Flame away!) so I don't think they will be too bright.
Over the years I am truly amazed at what someone should be able to see and then doesn't.
JMO
