Background:
Full drag only Gen1 1397 13.5:1 JE pistons, lightened/balanced APE crank, Carpenter ported head w/ heavy cams (going to give Bob a call and verify cams next week), Hays slider.
Currently running Sunoco 260 GTX (93 motor octane). Upon seasonal tear down, i find out that the throttle bodies (bottom side) are sticky with green residue from the fuel, the pistons and head/valves are rusty looking. It cleans up but not real happy with the outcome.
Currently the fuel system is 100% stock BUT its on the schedule to get a full upgrade. Pump, rail, regulator, injectors.....
I want to convert to E85 because of the high octane and cooler burning fuel (for the stupid hot days here in South Dakota!) Plus I have access to straight ethanol from the ethanol plant.
I'm sure its been done but if anybody has as guidance that would be great. Research is telling me ~ 30% more fuel over my current setup. Knowing i need bigger injectors, i am at the process of tackling new fuel at the same time as new injectors...
Does anybody have any specific injectors they would recommend? Also using the ECU Editor/WRT to tune the ECU. Also have a PC5 and a PC3 (no, not at the same time)
