Haya01B
Take a look at the clutch salad I just pulled out of my buddies 04 Busa! Every one of the stems that the spring bolts attach to were loose with not a spec of lock tight. The one that did come loose destroyed the pressure plate and broke the spring which I believe parts off are in the oil pan so that will also have to be removed and cleaned. Metal shavings everywhere!
Any other suggestions on what to check or replace? So far the clutch plates look good inner and outer hub are scuffed but not cracked or broken. The Clutch Cover took a beating but will survive. So far the parts needed will include clutch spring, screw, stem, couple washers, and most important Pressure Plate. I have some spare springs and the other parts are not very expensive with the pressure plate being the most expensive at around $32.00.
