I just aquired a 2000 with 9050 miles that has sat up alot. The fuel pump was changed a will back. My friend said the tank was cleaned but they forgot to unplug breather lines. He said it would run for about 30 min. and die. Well when I got it I put some wire through holes sprayed kroil in them and it seems like they opened. Put the tank back on and now it wont start at all. So far, fuel flows out the lines from the tank good, i ran the pump in varsol, opened the injectors and sprayed varsol through them. Still nothing. So i changed and checked the plugs and there is some spark. However, i can run my finger in throttle bodies after cranking and they feel dry and I dont smell fuel. Not sure where to go from here, but it seems like there is some common issue. Any help would be appreciated thanks. Also, just to see what would happen I sprayed a blast of starter fluid before cranking and nothing. Seems like even a little spark would cause something to happen.
