Do you think it would work to put washers on both ends of the spring so it doesn't ride directly against the idle screw or the housing? Washers might allow the spring to do whatever it wants while not upsetting the idle screw. Since the spring is only there to apply unidirectional force to the screw (straight out), the washers might isolate it enough to do it's job. Worth a try! Thanks for the idea.
Should do the trick also as long as the washers don't clutch. I think that going beyond the idle speed then dialing down to it would also torsionally load the spring in the helpful direction.
Good Luck.
Good Luck.
