Hi Icemansid.
so by compressing with your hands you are connecting the inner hub to the outer which is easier to hold while undoing the central nut, is that the reason?, sorry for so many questions but I am not home much and I like to be prepared as much as possible to get it done without to many surprises, I guess I was just hoping that as the clutch centre shaft seems to sit on the split line of the cases I could just turn it upside down and lift the bottom off with the clutch in place.
What about the sump, do I need to remove that or can I just leave it on the bottom case?
Thanks
Paul
Thanks
Paul
