Got all the injectors tested and a new pump and filter assy installed.
I'll start with the bad news...
Neither issue has been resolved. The bike STILL jerks/hesitates badly in the upper RPMs, and the idle is STILL rough. I will say that the idle seems to get worse as the bike warms up. When the engine is relatively cold, the idle is smoother, especially with the gear in actual nuetral. With the bike in gear and the clutch pulled in, the idle is much smoother, so it seems to affect neutral itself more than any gear with the clutch pulled in.
A few photos that I wanted to share:
1. My old pump was absolutely filthy:
The 'shiny' black part is where I ran a wet wipe over to show the difference. When I reassembled everything, I cleaned off all of the electrical connections as best I could. I should have taken an 'after' shot, but it looked exponentially better. I just coulnd't believe how dirty this thing was. I mean, INSIDE the tank shouldn't be this dirty, right? I used a flashlight and shone into the hole where the pump goes, as well as in the hole where the fuel cap goes. Everything I could see appeared to be clean, so this was bizarre.
2. Check out the gas that came out of the old pump and cartridge. It was friggin' BLACK:
I couldn't believe my eyes when I saw this. For those who have done this procedure before, is this normal? I can't imagine it is. Regardless, I got all of the old crap out of there and flooded the cartridge with TB cleaner until everything that poured out was clear. All the gas I pulled out of the tank prior to doing this was crystal clear though, so it must have been something in either the old pump or the cartridge. Also....I didn't take a photo, but the mesh screen filter on the pump assy was pretty clogged too, so that was replaced with a brand new one.
Finally, I was able to pull all the injectors and test them. Each has a good spray pattern, and there was zero signs of leaking or clogging. I ran each one through this motion pro cleaner I bought for 10 seconds or so.
So after a good cleaning of the injectors, new fuel pump and fuel filter, still getting the exact same indications. Rough idle and severe hesitation in the upper RPM range. Oh and the hanging rev issue is still here as well.
The good news? Well the bike feels like a whole different beast. Throttle response is AMAZING. I mean AMAZING. I damn near lost control a handful of times while casually riding around town because the slightest increase in throttle commands big time 'oomph' now, and this is all low RPMs. So that is good news. Also, the power delivery feels MUCH smoother. It was smooth before (compared to the ZX6R I had previously), but now it's even better. So maybe the injectors had some slight clogging, and changing out the fuel mesh filter helped as well.
So now as far as troubleshooting the issues, I mean, at this point it would have to be either a sensor, or something electrical? I'm going to check the TPS again sometime this week to see if the work I did + the valve adjustment threw it off. If it turns out to be good, I may just replace it to see if that helps. Other than that, I mean, could it be the plugs? They are new, and the gap is good. Or maybe the coils?
Shaun
