Shaun Ketterman
Sounds really interesting, did the guy who rode the bike, offer any explanation or how your bike could have a bent shifting fork or how it could affect the bikes running so much?
I didn't even mention the rough idle to these guys again, I just wanted them to replicate the stutter I was getting. His best guess was a possible bent fork, but for sure 2nd gear was slipping big time.
I'm thinking 2nd gear is bad.
I doubt the shift fork(s)are damaged.
If they were, there should be noticeable shifting problems.
No issues shifting at all, it's perfect in every gear. That gives me a little relief. The warranty, as I confirmed, is only 50 percent parts and labor, so I'm still on the hook to shell out some cash.
These dudes at the dealer are wanting to test everything before even considering the tranny. They want to put a new gas tank on there (after I told them I JUST put a new pump and filter, Ima fight that one), and they want to put a different ECU on there just to rule it out. The dealer also has a guy who is big into Busa's, and they want him to ride it around today to get his input.
Regardless, I'll keep you guys in the loop with how things play out.
David - I haven't read all of your other threads front to back...any chance your upper RPM issue is the same as mine? I think the fact that for me, it's only 1st and 2nd gear, makes it seem obvious (in hindsight) that it's the tranny.
