202mphbusa
relief valve would not hurt for sure
Thank yourelief valve would not hurt for sure
I am just trying to figure out what cause that bearing failure before I start rebuilding again my engineIt seems to me that if you increase the psi the oil pressure relief valve opens at, that is increasing the amount of oil in the engine while it runs and decreasing the amount of oil in the oil pan. The high volume pump is already reducing the amount of oil in the pan because it sucks more oil up.
So my guess is NO, a high psi oil pressure relief valve won't add available oil to the oi pan, it does the opposite. Same with the gear. Doing both would increase the chance of oil starvation.
That's just conjecture on my part. I've only had stock oilling on stock bikes so far .
I would want to know the cause of the bearing failure before spending the time and money to rebuild too.I am just trying to figure out what cause that bearing failure before I start rebuilding again my engine
For sure I will appreciate your help to guide me, but at the same time isn’t it strange that the engine is running without any problems for 3 years as a stock engine after rebuilding it and putting hell of passes and street driving on it, and then about 4 months on turbo stage 1 without any problems also till I just changed the gear and after 20 min the bearing was destroyed???!!!I would want to know the cause of the bearing failure before spending the time and money to rebuild too.
It's possible the oil pressure switch is malfunctioning and might not have come on.
Even so, stock oil pressure switches aren't of much value except for as as engine startup precaution. Oil pressure switches don't light up unless the oil pressure is extremely low, like 9 psi. The stock oil preesure warning light would probably not have given you enough warning to shut the motor down before damage occurred. An aftermarket oil pressure gauge with warning light would be a good mod if you don't already have that. I've installed one and I can guide you in that if necessary.
I would say the rod bearing damage happened from lack of lubrication but it might not have been lack of oil pressure. Maybe you have some obstructions in your oil passages? I do not know how to check or fix that but I'm sure there are ways.
That is strange. It seems like using the aftermarket gear must be related somehow. For the rebuild, I would go back to the stock gear and figure out some way to test the oil level at maximum rpm.For sure I will appreciate your help to guide me, but at the same time isn’t it strange that the engine is running without any problems for 3 years as a stock engine after rebuilding it and putting hell of passes and street driving on it, and then about 4 months on turbo stage 1 without any problems also till I just changed the gear and after 20 min the bearing was destroyed???!!!
What about running 5 liters of oil?I have heard of shimming stock oil pressure relief valves. That would be a way of increasing oil pressure in steps if you can figure out some way to check that the amount of oil in the pan is sufficient. If you want to change the thickness of the shim in the relief valve to achieve higher or lower oil pressure You could do that to avoid running the oil pan dry at peak rpm.
Of course, I'm going on the assumption that the oil pan running dry is what caused your rod bearing failure. The bearing failure might have been caused by something else.
That seems like a huge amount of oil. I think the cold check level would be above the site glass. I guess you would need to insert some kind of dipstick to check the oil. I believe you would get oil up in the air box if you had too much oil.What about running 5 liters of oil?
Are Accusumps a thing anymore in this context?
Nothing unusual until now everything is fineAre Accusumps a thing anymore in this context?
Never here’s about it beforeAccusump Oil Accumulators - how do they work?
Accusump Oil Accumulators - how do they work? Merlin Motorsport article answers this question.www.merlinmotorsport.co.uk
They used to be widely used in Auto applications, Not sure I have seen one used on a bike though.Never here’s about it before
Me tooThey used to be widely used in Auto applications, Not sure I have seen one used on a bike though.
I talked to Dan at mps yesterday, really about my trapped door 2" pan. Directions say eyeglass is obsolete, use 5.5 - 6 quarts oil. The answer is.... Oil pressure drops at shutdown. But I did ask him about the oil pump gear because I have been wondering myself. He said the gear is really for idle. anything under 2,000 RPM. After that the pressure relief is what matters. Also said he had mixed feelings about it but using both wouldn't hurt.I am just trying to figure out what cause that bearing failure before I start rebuilding again my engine
