Mythos
This is the first time I've heard of an Accusump too.Never here’s about it before
I had an oil gauge on a ZX-14 with stock oil pressure relief valve and stock oil pump gear. The oil pressure rose quickly to 60 psi at 4000 rpm and then the needle just stayed there until the rpm dropped below 4000 again. Based on that, I'd say an aftermarket oil pump gear would have gotten the oil pressure to 60 psi at about 2000-2500 rpm. The oil pressure would still not go higher than 60 psi though. If the valve opens at 60 psi, that's what your max oil pressure is no matter how fast the motor turns. The aftermarket relief valve by itself was recommended to me by most people who advised me. The gear uses additional horsepower at all rpm. I can see how the high volume gear with or without the aftermarket relief valve would be of benefit at low rpm and that might be more important for a turbo.He said the gear is really for idle. anything under 2,000 RPM. After that the pressure relief is what matters. Also said he had mixed feelings about it but using both wouldn't hurt.
However, Aly's problem seems to be having the high volume gear, not NOT having it. Further, I think he said he heard the engine knocking while the bike was idling in the garage. From our conversation, that would be the rpm at which a high volume gear would actually have been increasing oil pressure. Increased oil pressure shouldn't cause decreased lubrication to rod bearings. The problem remains a mystery.
